1 - 2 of 2 Posts
Hello Everyone i recently purchased a 2015 R3 and have a few questions. How often should i lube the chain and what is recommended? What type of oil should i use? And Also any other fluids i should be aware of and check on a regular basis? Thanks In Advance!
Chain lube / check at 500 - 600 miles. I use a chain lube that penetrates and condenses down almost to grease. It does sling a bit, bur penetrated links and pins better than wax. Also check coolant level, brake fluids. Read owners manual for specs.
1 - 2 of 2 Posts
