I'm trying to install a healtech shift light pro on my 2020 abs r3 does anyone know what color the rpm signal wire is?
Dumb question. What's wrong with the OEM shift indicator light (and gear position display)? That's all I use on my race bike ...
That aside, if the device is intended to operate on an ignition-coil trigger wire, that stuff is together with the ignition coils under the front of the fuel tank. On the low-voltage side of the coils, whichever colour of wire is the same on both coils, is the switched +12V supply that is common to both coils. Whichever colour is different between the two coils, is the trigger wire that is grounded by the ECU in order to command an ignition event.
I do not know if this engine uses true sequential operation (one ignition event per 2 crank revolutions) ... there is no cam position sensor, but if the ECU susses out which crank stroke is compression versus exhaust based on the fluctuation of the crank sensor signal, it wouldn't be the first to do that.
Don't use a fuel injector trigger wire. It will show zero during shut-throttle deceleration ... ("deceleration fuel cut")
The stock equipment can only be set for two parameters with the slp I can set 3.... more of a luxury than anything
