Im away from my bike for three weeks or so. Can someone put a mic on the rotor and tell me the bolt to bolt and inner diameter numbers at the hub interface?
I know its 298mm outside diameter, I believe its zero offset too, right? 6 mounting bolts?
If I can get these numbers I will reach out to try and fund another model to get a bigger rotor off of.
Thanks!
You used to be able to get the numbers from the Australian company MetalGear, but they don't share this info any longer - but they do post pics of their discs. Here are 2 options that, dimensionally, look like they have the same 5 bolt pattern. They all look like they have zero offset and are floating discs, so I say here are 2 options to look closer at. The 01-05 FZ1 1000 really look promising except the stanchions are 43mm.
Are you going to make a spacer to offset the R3 caliper to the new disc or will you use a different [fixed] caliper and spacer?
