Hi just got the R3 put together, standard apart from delkevic exhaust (cat still on) took the bike round the block and it felt like there were flat spots in first and second gears, ok in third upwards, the issue is more pronounced if you have low revs and try to accelerate its also okay if its whacked open, anyone else experienced this?
cheers
thank you, it is a weird sensation when it hits though, I have taken most of the slack out of the cable, so will look to do the R6 mod!
cheers
Marshy UK
The R6 tube "helps" in the sense it gets you to wide open throttle quicker/easier, alleviating the flat spot sensation by being at wot as you mentioned.
A fuel controller with appropriate map (Powercommander or bazazz) is what you will need to truly get rid of that flat spot.
