I've commented here that the stock Michelin Pilto Street tires were an acceptable tire on the R3. Now that the weather is warmer, I have had time to push harder in corners, that previous 40-45F degree weather did not encourage. I assumed that the lack of feel and harsh ride were temperature related. However they also tended to get hot in the middle only, leaving the shoulders cold, which is not great.
That said, a couple of good long runs in 67F weather encouraged me to push a little harder. What I discovered was that the Pilot Street bias ply tires are not up to aggressive riding demands. Mine were particularly bad, as they are 6 years old by date code. The bike had only 300 miles on it in November 2021, so I suspect they were not properly stored by the P O., which made them harder still. Going into corners was never an issue, they were quick enough and solid there. It was corner exits that caused a lack of confidence for me, mainly with the front washing out. In long fast sweeping turns, all was good, until lean angles approached 35 to 40 degrees, when both front and rear began to feel precarious, sapping confidence in them. Sharp bumps like railroad track crossings and frost heaves caused the rear to bounce uncomfortably, leading me to feel they are just too stiff and hard for such a light bike. The bias construction makes them very round compared to radials, which have a more triangular shape (to increase contact at higher lean angles), which makes using their edges a bit uncomfortable. It was time for a change.
Based on reading and watching 1,343,271 reviews (estimated number, was probably more) on sports tires My short list came down to:
Dunlop GPR300 - $173 per set
Michelin Road 5 - $370 per set
Pirelli Diablo 3 - $244 per set
Bridgestone Battleax S22 - $233 per set (special price quote).
All have reviewed well, and perform very closely to one another in tests, with the S22 frequently at the top.
I decided that for the majority of the riding I do, a sports focused tire was my target, vs. Sport touring, so I set aside the Road 5's. Also not wild about how proud Michelin is of them (price).
I have never had great luck with Dunlop tires in general, so decided to set them aside, although they are a great tire for the price, and felt good on the '19 R3 I rode last year while searching for my bike.
The Pirelli's are also an excellent option, so it was them or the S22's. I like Pirelli, so they were my top choice at one point.
I had S20 Evos on my Aprilia Falco and I really liked them, which is the foundation of the S22, Further the S22 is one of the highest rated sports/street bike tire, winning its share of shootouts, while suffered few bad reviews over many years and evolutionary steps. Wear has been the target dig at them, and that mostly on liter bikes, with far more power and weight than the R3 presents.
So, this is how I came to the Battleax S22's as my final choice, which were mounted today. I will get them scuffed in between now and Sunday, then add my thoughts in a follow up, as well as one at 1000 miles later this summer.
Note: Te short list above was nit comparing apples to apples across the board. The S22 would cross more directly against:
Pirelli Rosso Corsa 2 - not available in proper sizes
Michelin Power R5 - not available in proper sizes
Dunlop Sportsmart Mk3- not available in proper sizes
The tires sizes available creates a need to compare products that are not specifically equal, but similar.
