1 - 3 of 3 Posts
8/2016 YZF R3 ABS.
I have removed the ABS from my bike.
To keep the speedo and odometer working, I left the rear wheel sensor on. I removed the aluminum block from the ABS ECU and zip tied ECU up to the frame.
Question, can I remove the ABS ECU and join the Br (Brown) and Y (Yellow) wires, from Rear Wheel Sensor to wires going to the ECU , eg. join Br to B or B/W ?
And join Y to W. From the ABS ECU connector ?
I see there is an ABS ECU eliminator, available in the USA, this is A$400.
My next step is to disconnect the W/L (White/ Blue) wire to the ABS warning light and see what happens ?
Can anyone help with advice here ?
What are you planning to do with the OEM ABS kit of R3, I have a Non-abs bike, and if this fits, would like to buy it from you..
Very difficult to add ABS to your bike.
You would need new wiring harness and ECU, + all the ABS components.
Not possible.
1 - 3 of 3 Posts
