1 - 2 of 2 Posts
Hi guys, this one is going to need all your expertise, i have a 2015 abs model. The bike was stolen and the little punks , for some reason, had cut out the front resevoir and hose. I replaced both including a genuine Yam brake hose.
Bled brakes both have pressure both haul the bike up, however the abs light is on the dash, i read in the manual that if you turn on the ignition and pull the brake you can feel the pulsing, I cant!, there is power to the connector at the solenoid part, i have also read it can be a sticking solenoid (pump).....has anyone got any tests , ideas, or checks i can do?
thanks
Marshy
1 - 2 of 2 Posts
