Hi,
successfully installed the annitori QS today
Went through the tests.
So, it cuts the throttle on upshift
and in the opposite direction it can also cut the throttle.
if I dont blip the throttle, and downshift without the clutch things could get bad as if I downshifted and dumped the clutch abruptly?
can I try blipping the throttle without grabbing the clutch handle?
Anyone with the annitori, experience with setting it to cut throttle on push and pull?
settings numbers?
Thanks
I only run it for up shifts; disabled the opposite direction. Without an auto-blip there's now way I'd try a clutchless downshift. Too risky as my throttle control isn't perfect enough to get the same blip under braking every single time.
Sent from my iPad using Tapatalk
What they said!
Don't try to outsmart everyone else in the world by thinking you can use a QS to do clutchless downshifts lol...you need an auto-blipper for that. On downshifts, you want throttle, exactly the opposite as upshifts. Technically it's possible to downshift without the clutch on any bike, but it's very rough, not very precise, and not good for the transmission. And if you can do clutchless downshifts on the track and think it's not a problem, then you're certainly not going fast enough! ;)
