I own a 2019 yamaha R3 and recently purchased womet texh bar ends amd the brake side went on perfectly fine, but when i did the clutch side i nriced my weight was extremely loose and i pooled alittle bit and it slid right out. I went to slide it back into olace but it will only slide half way and won’t even let me put all the way back in. Any suggestions or has this happened to anyone before?
Hey man, can you report with more info and with pics Pls! Not sure if I follow.
I had an issue where I bent my tabs on the weight and it kept sliding out during rides due to vibrations.
Discussion Starter #4
I got it back in, the problem was the round part that held them in place was cracked had to order a new one but got it all figured out. Thankyou tho!! Also im doing a sprocket change whats the best ratio to do for these bikes?
