1 - 2 of 2 Posts
Hey guys.. My bike tooke a fall at approx 20 km/hr on the right side.. it starts up but sits at 3k on idle.. once I put it in gear and slightly pull the clutch it drops to 1500rpm. If I put it back to neutral it will sit at 1500 until I turn the throttle past 3k at which point it will continue to idle at 3k once again. Other times the bike will idle at 1500rpm without problem. Any advice?
It may be your throttle tube or a cables that is either snatched on something, moved out of place, or broken. you may want to check everything before riding as you don't want to be riding and the bike surprises you out of no where.
1 - 2 of 2 Posts
