Thanks to @GoFaster, now I know which piece I broke:
Fork Tube Check Valve
and that sounds better than what I labelled it as.
I broke it when I was attempting to slam together the valve body (like an idiot), thereby with crushing force - chipping off a chunk of this plastic inner fork tube doohickey.
@GoFaster asked for a frame of reference (rightly so); the pictures below are the inner fork tubes, upside-down, where the plastic bottom-out sleeve is inserted. Just above the outer lip, the lower slide bearing clamps to a machined slot on the outer fork tube.
