Hello guys does anybody else have the same problem when you connect to the ECU with OBD.
since a month ago I changed my engine oil from 20-50 to 10-40 and my r3has been giving problems with power loss. my r3 also dies on idle and I have done almost everything to solve that but it does not work and we don't have a Yamaha workshop in my pace. SO anybody with some tips to help me would be really helpful, I don't want to throw my R3 away.
no mods and its 5000 KM only.
· Super Moderator
2016 Yamaha YZF-R3
What does your owners manual say is the recommended oil?
OBD will only help if you have a check engine light.
I did add the recommended oil also. 2.2L I was using motul 20-50 7100 and then on 5000km service I changed to motl 10-40 7100 and then I started experiencing powerloss. one mechanic also changed settings with the o2 screws and now it dies even faster than before. I think I would hence forth diagnose it myself.
· Super Moderator
2016 Yamaha YZF-R3
The O2 screws? What are you talking about? Do you mean the throttle body screws?
Changing oil shouldn't cause any issues, unless you've been running a massively wrong oil for a pretty good amount of mile/time. 5000km is not that long.
The issue is probably whatever your "mechanic" did and you should take it back to them and have them fix it.
