R3 is most definitely fuel injected. Not sure why there is a vac gauge for carb synch.
Hard starting, not starting, rough idle, poor acceleration, rough running (exceptional vibrations) throughout the rev range... to name a few. Note that ALL of these symptoms can be caused by other things as well.What are signs for unsynchronised throttle bodies? Is it really important to sync?
Both throttle bodies have a rubber cap that covers the vacuum hose. Remove the caps, plug two of the tool's four hoses onto them, start the engine and measure.What do you plug it with?
How easy is it to adjust using the motion pro?
I dont have my manual at the moment and not sure the location of the adjuster, is the throttle body #1 adjuster on left of tank or right of tank, looking at bike to the front?Both throttle bodies have a rubber cap that covers the vacuum hose. Remove the caps, plug two of the tool's four hoses onto them, start the engine and measure.
The expensive Yamaha tool is probably digital and tells you the actual pressure at each. The Motion Pro tool has four tubes with liquid, like thermometers, that give you a visual representation of the pressure difference. It's the same procedure with either tool. If the throttle bodies are off by 2 kPa, you need to adjust. Only adjust throttle body [URL=http://www.r3-forums.com/forum/usertag.php?do=list&action=hash&hash=1]#1 [/URL] and use #2 as the standard. All of this info starts on page 3-8 of your service manual.
Yamaha recommends you sync the TB's at 4000 mi (6000 km), then every 3000 mi (5000 km) after that.
haha that's a good question. It's hard to tell from the picture what the he11 I'm looking at. My best guess is #1 is on the right side of the bike as you're sitting on it.I dont have my manual at the moment and not sure the location of the adjuster, is the throttle body http://www.r3-forums.com/forum/usertag.php?do=list&action=hash&hash=1#1 adjuster on left of tank or right of tank, looking at bike to the front?
Then I can't figure out for the life of me what the diagram from the service manual is showing.Avila, when identifying bike cylinder configurations, you always call out the cylinders as if you're sitting on the bike (facing forward). Cylinder #1 is always on the left, then they count up as you move towards the right side of the engine.
Yamaha tool has been discontinued. And yes, the service manual is your friend -The expensive Yamaha tool is probably digital and tells you the actual pressure at each. All of this info starts on page 3-8 of your service manual.
Remember, items and orientations are called out as you're sitting on the bike. In the top left pic's view, you're standing next to the LH handlebar looking towards the throttle bodies and airbox (gas tank is removed). In the mid-page right hand pic (A) you're standing on the LH side of the bike looking at the gas tank. Pic (B), you're on the RH side of the bike looking at the gas tank. Notice the airbox in both pix for reference.Then I can't figure out for the life of me what the diagram from the service manual is showing.
Oooooh it's two separate pictures. I thought it was one big picture and it was so confusing, thanks for the clarification. You'd think in this day and age they'd put a color picture or hi-res photo in the manual.Remember, items and orientations are called out as you're sitting on the bike. In the top left pic's view, you're standing next to the LH handlebar looking towards the throttle bodies and airbox (gas tank is removed). In the mid-page right hand pic (A) you're standing on the LH side of the bike looking at the gas tank. Pic (B), you're on the RH side of the bike looking at the gas tank. Notice the airbox in both pix for reference.
I know, right? Wuddaya expect for a [choke] $75 book?Oooooh it's two separate pictures. I thought it was one big picture and it was so confusing, thanks for the clarification. You'd think in this day and age they'd put a color picture or hi-res photo in the manual.
I did my throttle sync almost two weeks ago. I posted my DIY tool on the Active topics under the Throttle Body Sync section. Hope that helps. I read a lot of people saying that they didn't think it needed to be done, however, my throttle sync was way off at just shy of 8,000 miles. This was the first time I ever did one and had great success at it. Oh, and BTW, I did not take the gas tank off to do the job. I just lifted it up and on the air box. I am happy I decided to do it.Has anyone bought the Motionpro tool? It says you need 6mm adapters for Yamaha's on the site, just wondering if that's the case or not? Wonder if anyone's done the throttle body sync? I watched a couple videos that were done on the R6 and it looks super easy.
