in the service manual, the last step in the diagram is to remove brake caliper bleed screw, while in the jobs section it says to loosen the bleed screw and push the piston, then install the pads and spring. Does the step in the diagram meant only to loosen (so it is part of pushing the piston), instead of removing the screw, which I think will also release the brake fluid?
Do i need to bleed the brake after installation, since the bleed screw was opened?
