Common R3 torque values
40737 Views 19 Replies 14 Participants Last post by  enshiu
I made this cheat sheet of the bolts I most encounter during general and emergency maintenance when working on my bike for race weekends, track days, and general maintenance.
If there is something you think is missing I can add it to the sheet. I keep a copy taped up in my tool box so I don't have to refer to the service manual all the time.
Best to print it up in landscape mode.
https://docs.google.com/spreadsheets/d/1KwLoeQ0bSD5G0t6Y-uJckKRID58ZVN4PwtJJtfGY1Mg/edit?usp=sharing
  • Love
  • Helpful
Reactions: 5
1 - 20 of 20 Posts
That is outstanding. Great job on that. Can I get that in a .JPG image file? I just wanna store that puppy on my local hard drive.
Nice one mate thanks for doing it,got it printed up and stored in my mancave.
Buy this man a Beer!!
Thanks!
If you click on the File tab you can download it in .pdf, or other formats. I couldn't make it a .jpg since I did it in google docs.
Okay, I just downloaded it as a PDF. That works. Thanks again!
Thanks for this. Comes in very handy!
Anybody have a recommendation for a good torque wrench they've used/use?
I have one from Tekton. Got it from Amazon and works pretty well. Got it for around $38
You can spend a pretty hefty amount on a torque wrench. I have heard the Harbor Freight are not to bad. Biggest thing is to take care of it. Don't let it fall on the floor.
I found my torque wrenches on eBay.
I couldn't find a nice quality small torque wrench with inch-pounds like my dad has in his tool set. Where??
The only click type torque wrenches that you can trust have to be very good quality and can be expensive.
I have had 2 Craftsman beam type ones (1/4" and 3/8") for over 30 years.
I tested them once and the errors were less than 5%. That's good enough for the girls I dance with. :D
I have a Matco 3/8", and Mac 1/4" and 1/2". I picked them all up on eBay. 1/4" is what you want for inch/lbs. A torque wrench gives the most accurate reading when it is in the middle of it's range. So, while I could do 10 ft/lb with my 3/8" wrench, I always use my 1/4" because 10 ft/lbs falls more in the middle of the 1/4" range. It is on the bottom of the range for the 3/8".
I do have to admit though, I am a tool snob. I prefer the higher end tools when I can get them. If I didn't have a choice though, I would pick up a harbor freight 1/4" if I absolutely needed a torque wrench and couldn't find one for a decent price. Like I said, I have heard they can be pretty accurate for what they are.
This is a search for used torque wrenches on eBay
Thanks I will check Craftsman again. Price isn't an issue -- just that my 20 minute online search gave me nothing but larger ft-lb models.
I just printed one out and framed it to a wall here at the shop :) Thank you!
If you can afford it get a SnapOn. for 20-100 lb-ft the others will do but for anything low torque I wouldn't trust anything else.
Yamaha R3 Common Torque Specs
Hello I am putting a new oil pan on my 2015 r3 is the motor bolts the same for the oil pan bolt torch thanks
I have been getting a couple of requests to have edit access to the torque sheet. If there is something that needs updating or adding please post here and I will add it.
If an admin would like access just dm me and then request edit access after I have your email via dm.
Thread - Torque
M4 - 5Nm - 3.7 Ft/lbs
M5 - 8Nm - 5.9 Ft/lbs
M6 - 10Nm - 7.3 Ft/lbs
M8 - 20Nm - 14.75 Ft/Lbs
M10 - 40Nm - 29.5 Ft/lbs
M12 - 80 or 100Nm - 59 or 73.5 Ft/lbs
1 - 20 of 20 Posts
