Hey so I was trying to do a simple task and change my front brake pads out... I stripped one of the t50 torx bolts because they were torqued down like unbelievably tight... so I ordered a new bolt and drilled a slit in the stripped bolt to remove it. I didn't take the abs line off because I'm dumb and I thought it was fine, ended up nicking the abs line so I took all the necessary covers off, unplugged the abs line and removed it from the bike. Does anyone know where I could find the part number for the OEM abs front brake cord?
- Red outline is the abs line
- This is the front of the cord where it screws into the rotor
- This is the end of the cord where it just plugs in to the receiving end under the tank
- Receiving end
Thanks for any help :)
Discussion Starter · #2 ·
Nevermind I found it under electrical and not the brakes...
part number is: 2WD-85970-00-00 for anyone who needs it
I'd be interested to know how much the dealer charges for it if that's the route you're taking? It'd probably be a fraction of the price if you get it off a wrecked bike or someone who's taken their ABS off for the track.
$75 off partzilla, not too steep but avoidable in my case
