Gasket
4YS-E1198-00-00
Retail Price: $3.23
Marc
4YS-E1198-00-00
Retail Price: $3.23
Marc
What size do I need?Just go to harbor freight or McMaster and order a bunch - less than a buck apiece. Or, if copper, you can re-anneal it and use it again.
I will just buy a set like that from HF thanks.I had some extras in my stash - I think they are 10 mm ID (verify). I bought a set similar to this a while back and have been working off those.
http://www.ebay.com/itm/110-PCS-COP...TORAGE-CASE-/161762346037?hash=item25a9c98435
I'm not sure what Yamaha uses for the R3, but true Crush Washers aren't just flat copper washers.I had some extras in my stash - I think they are 10 mm ID (verify). I bought a set similar to this a while back and have been working off those.
Is the OD on these ok? 16mm OD, 12mm ID?Turns out drain plug is M12x1.5, so yeah, a 10 mm would not work so well - my bad.
Edit: Source for crush washers - about $0.40 apiece when you get 25 - share with friends, be popular with the R3 crowd....
http://www.mcmaster.com/#97725a250/=zvaiy5
Just get the bolt size and get a washer rated for that (slightly larger will also work). It might a 8mm bolt for the coolant drain plug iircCoolant drain plug washer is different. It's not totally flat and looks cooper. Anyone know where to buy those?
Jeez. Maybe I?d be better off paying the $7 eBay wants for the ease of it.I haven't managed to find a confirmed source for an OEM one, but the Yamaha stealership wanted $4.50 for 1 of these washers. I told them to eat d*ck
Don't throw a pissy fit at the dealer, yamaha sets the pricing not them.I haven't managed to find a confirmed source for an OEM one, but the Yamaha stealership wanted $4.50 for 1 of these washers. I told them to eat d*ck
