yea my bike does like 58mpg and thats a picture of the top right of the page and yes the exhaust cuts the cat and also thats why im saying its weird that i did these upgrades and its saying im making 37 i feel like its not right but low end power definitely increased and my bike is broken in i bought it new 1yr ago and i now have 11k miles and i just wanted to squeeze more power i think im also gonna get a ecu flash soon and slipper clutch and im getting an r1 this yr i like to mod the toys i buy its a fun project getting to do everything myself im planning on keeping this bike till the engine dies so i wanna do all the upgrades i can
Your chart shows SAE correction and smoothing = 5, both of which are fine. The dyno chart seems to reflect a dyno run properly done.
You realize that when you flash the ECU, you will need to either remove the Power Commander or set it to "zero changes" to the fuel signals being sent by the ECU? Otherwise, your Power Commander will unfavourably alter the new (reflashed) ECU tune. So, you will have a "deviant" tune thta combines both the Power Commander tune which reflects the costly dyno tune you had done, AND the reflashed ECU tune which will also cost you $$$. This deviant tune could damage or blow up your engine. I'm not exaggerating. And, if you "zero" the Power Commander you will wipe your costly dyno tune!
Bottom line: If you reflash your ECU, zero the Power Commander BUT only after you ensure you kept a copy of the dyno tune you paid for somewhere, either on your computer or on your tuner's computer. Othersie, you will lose what you paid for. Plus, this way, if you don't like the reflash on the ECU, you can go back to the OEM tune on the ECU and re-install the Power Commander dyno tune.
Your description of yoiur plans show that you have not done your homework on how electronic tuning via either ECU or Power Commander works. You need to do that homework before you blow either a lot of money OR blow your engine.
You can't learn what you need to know by posting here. You need to read online articles that explain how electronic tuning works. If that is too much trouble for you, stop screwing aorund with your engine because you can easily do a lot of damage.
It looks to me like your tuner did a credible job. Abandon your dreams of big power from this 320cc engine for a few more hundred dollars. It's not going to happen. Enjoy the engine instead of screwing it up.
Jim G
