So I have a 2019 R3, it's my baby and it's my first motorcycle, I was putting a front axle slider from T-Rex Racing on it, and over tightened on one side, so the m6 screw keeps spinning on the left side keeps spinning thus not allowing me to remove it. Any suggestion on how to remove it? Lesson learned on over tightening. Attached are the instructions that came w/ the Front Axle Slider
You might be able to use some "red" loctite on the threads on the side you got out. Let it dry good. Once it's hardened enough you should be able to get the other side to that was overtightened to break loose. Once you get the assembly out, you can put some heat on the side with the loctite to get it free. Good luck-
Related Threads
Yamaha R3 Forums
107K posts
10.3K members
Since 2014
