1 - 3 of 3 Posts
Hey guys hope everyone is doing well and riding safe! I am looking for some help in the right direction. I went down about a month ago (low side right side). No cracked fairings but I did manage to sustain damage to my headlight. On the left side the part that allows the cover socket (#4) for.access to the bulb broke thus no not being able to cover. During night rides on high beam the glare is not fun. I'm looking to replace this part but it looks I have to buy the entire Headlight Asst (#1) or is the part needed the Headlight Unit Asst (#3)
Hope I was clear enough.
http://www.procaliber.com/oemparts/a/yam/54fdc9b887a86510e8210468/headlight
Looks like you'd want to get #3 if you want to replace things to factory spec; however, it's expensive enough that I'd instead suggest looking into improvising a retention system using cheap hardware from your local hardware store. You probably don't need to get very fancy with it either since that area isn't something that gets serviced often.
1 - 3 of 3 Posts
