1 - 10 of 10 Posts
Thanks honestly didn't know this forum excited till my friend told me that there was awhile community just for R3. Between working. Crazy hrs i need to squeeze time to edit my headlight conversion video. Which is the devil eye headlights that I did for under 300. I'll try to get that out to u guys asap
Here is a link to my utube channel for a how to video I did to install a rear tire hugger. Once on my ch you will other how to videos I did for my R3. Also links to where I bought the items I install in the description.
http://youtu.be/swnt3E9mlZM
Hey, did you make your holes bigger to slide it further back a bit, or did you make additional holes behind the original ones ?
Mine is almost touching tires, the little hairs on tires are touching the hugger :)
i had to re drill new holes, i had the same problem when i got mine also that it was touching the tire.i installed the bracket but left the scoop not attached so i can re-position it to make the new holes. once i found a good position i marked the holes and reattached it.
Yup, had to drill new holes slightly behind the original ones.
Now I'm trying to figure out how to install swingarm spools, since not it's not a flush mount point anymore.
Great looking hugger, but it makes you work for it :)
1 - 10 of 10 Posts
