Seeing as how getting less forward lean was covered elsewhere, I thought I would ask about my goal of having MORE lean. This is my first 'sport bike', I'm about 5' 7", and the general feel of the bike to me seems very upright. In my eyes this gives the bike more of a beginner bike appearance ... I find this undesirable (yes, I understand to most it IS a beginner bike, but this really is all the bike I trust myself with!). I'm fairly used to a lot of forward lean as I'm into cycling (the pedal kind) quite a bit...
Thus far I've moved the handlebars from on top of the upper triple tree to below, using spacers and 6M x 40mm bolts to recreate the bar angle locator system they had going on there. I then encountered some rub from the throttle cables against the black plastic of the fairings. I remedied that I believe by rotating the throttle so that the cables exit above the brake lever (this required drilling a new indexing hole for the throttle/switch assembly)... as a side benefit this put the start switch in a fairly hidden spot. I still need to seal up the drain holes that are now facing upwards. And this brings me to my issues:
1. While my throttle fix is OK ... I've seen aftermarket throttles online that do a much better job at exiting on the top. What I can't seem to really locate, and I think it is just my naivety in regards to sport bike terminology when searching, is a replacement switch assembly without a throttle associated with it... thoughts?
2. Foot peg/shifter/rear brake location. Now that I'm leaning forward more, it almost feels like these are too far forward. Again, not knowing much about sport bikes maybe that is how they are supposed to feel on the big bikes (e.g. R6)... is moving these rearward a common thing? or am I off in dream land here?
Thanks.
Thanks.
