1 - 10 of 10 Posts
When driving on a slight upgrade in sixth gear and tacking 9000 RPM what is you're MPH?
9000rpm should equate to 90mph unless your clutch is slipping.
That is correct! At 5' 10" and 220 lbs I was doing 90 mph.
At 9000rpm you should still be doing 90mph.It don't matter what you weigh or whether your going uphill or down you'll still be going 90mph.
Lol right, what was the point of "slightly uphill" ... 9K rpms is 9K rpms.
The point was that the R3 is highway worthy. Not to mention I was going 25 mph over the speed limit.
Yeah I'm confused. Are you asking if it will hold 9K uphill, or is this a subtle troll thread where you ask questions that you know the answer to already.
Discussion Starter · #10 ·
You are making much more out of the question than necessary.
1 - 10 of 10 Posts
