Hello. I wanted to get flush mount turn signals and ended up with these three pieces. However I am not sure how to wire them up properly.
The first one is the actual signal light with two wires [black and yellow]
The second one is the part that plugs into the R3 with two wires [black and black/white]
The third is supposed to be a LED load resistor with a male and female end for connectors and two unconnected white wires
At a guess, I'm thinking all black wires are ground, color are positive. The signal should connect with the connector in the second picture, black to black and yellow to black/white. Plug this new piece into the load resistor, connect the two white connections, and plug this now 3 in 1 piece into the bike. I never worked with bullet connectors so I guess just heat shrink/tape the connections to keep it from shorting out?
Gladly appreciate the help.
