So I found out what happened why my bike wasn’t starting, it has been parked for about 3 years in a shed so a rat had gotten into it and bit my fuel pump connector wires and my fuel injector wire connector Where can I find these or how can I fix them please help!
Maybe you can cut and splice in new wire as needed. That would be a lot less expense than a wiring harness and labor to install. Then you could spray the wiring with jalapeno juice. I did that when squirrels ate the wiring harness on a Ford pick up some 15 yrs ago. End of story.
Might be worth taking a look at your local junkyard to see if they have any crashed R3 you can extract the wire harness from.
Oof, that looks rough. That's gonna be quite a bit of work if you plan on repairing this harness man. I would look into getting a replacement harness unless you have the time for it.
