1 - 8 of 8 Posts
So, got a question. The Ohlins rear shock with remote reservoir model A467 has been out since the R3 has shipped. Now there is an Ohlins S46HR1C1L STX 46 Hypersport Shock SKU available for the R3.
Is there a huge difference? The former is about $750 but the latter costs around $950.
per nomenclature the YA467 is a S46HR1C1L so I'm not seeing any difference in feature set. The 467 comes from Thailand(?) and perhaps the additional 200 buys you one made in Sweden? It's also possible the latter has a race-oriented piston and valving. Kinda need the YAxxx number to do any further research.
Reactions: Stirz
Compare all the specs,
Eye to eye length
Ride height adjustments,
rebound,
compression,
hi speed,
low speed
Am interested to know.
Ohlins USA still doesn't list a fitment for the R3 as of time of this post, not sure why. Where'd you find this?
http://www.ohlinsusa.com/fitment
Ohlins Yamaha YZF-R3 15-16 S46HR1C1L STX 46 Hypersport Shock
All Ohlins shock absorbers are developed from knowledge gained from top-level factory Authorized Ohlins Dealer race teams around the world. Superior construction, superior materials and superior engineering skills give you the best quality shock on the market. The shock body is precision-drawn steel with an aluminum shock reservoir. These race shocks feature lightweight, high strength aluminum shock bodies with stainless steel, braided PTFE hoses used with all remote reservoir shocks. Springs are chrome silicone. All aspects of basic shock setup and performance are thoroughly tested to ensure the shock performs flawlessly. Ohlins shocks are 100% rebuildable so you get lasting quality - you can readjust, re-shim, and overhaul/rebuild the shock for years of peak performance.
While the TTX is the "latest and greatest", it's not available for every bike. However don't be fooled by how well the entire Ohlins line performs. It was only a couple years ago that track records were being broken by these shocks and they are still flying around the race track and in use today. Here at STG we've both ridden and raced on this shock and it performs. Many can't even tell the difference between this and a TTX shock.
S46PRCL Features:
46mm shock piston diameter.
De Carbon shock absorber with external hose-mounted reservoir and dividing piston.
Reservoir is extension of shock absorber body.
Allows for more oil and larger cooling areas for improved shock performance and durability.
Adjustable rebound and compression damping.
Adjustable shock length.
All aspects of basic shock setup and performance are thoroughly tested to ensure that each shock absorber performs flawlessly.
Ohlins shocks are 100% rebuildable - you can readjust, reshim and overhaul the shock absorber for years of peak performance.
Superior construction, superior materials and superior engineering skills give you the best-quality shock on the market.
All Ohlins shocks are developed from the knowledge and experience of top factory race teams around the world.
Stainless steel braided PTFE hose used with all remote reservoir shocks.
Shock body is precision-drawn steel with aluminum shock reservoir; race shocks feature lightweight, high-strength aluminum shock bodies.
NOTE: Your Ohlins shock absorber may look different from what is pictured. It could be longer or shorter depending upon the model application. On Type 46P shocks, the compression adjustment knob may be a screw. The shock reservoir could be angled differently in order to fit your bike as well. It just goes to show how much custom work Ohlins puts into making their product work on each and every bike.
Shock Type:
Single Tube
46mm Piston diameter
Monotube high pressure gas type, hose mounted external reservoir
Adjustment Features:
Found it at STG....HERE
whatever was the conclusion on the difference here?
Same model. The shock is the S46HR1C1L family (Type Code) and the model is a YA467 (Part #). Same shock.
https://www.ohlins.eu/en/products/motorcycle/ya-467--4988/
The Type Code is the coding for its features and specifications.
Shock absorber Road & Track YA 467 - Yamaha YZF-R25
Based on your bike’s performance, its price and available mounting space we have designed a shock
that we think suits it, both when it comes to price and performance.
We start by choosing a type which we tailor-make for your specific bike. The basic setup, the design of the
shim stacks and the calibration of the adjusters, is tested both on road and track. They are the results of true tests with your bike and no guesswork!
Öhlins manufactures more than 300 different shock absorber models, each model is tailor-
made for one specific bike. The concept of all Öhlins products is not a secret, it is precision. Precision provides superior control of the damping force and the key to our success.
Part number
YA 467
Type Code
S46HR1C1L
Category
S = Single tube
Type
type H
H
Monotube high pressure gas type of shock absorber with hose mounted external reservoir.
Adjustments
R1 rebound damping adjuster
R1
Adjustable rebound damping on single tube shocks. Adjuster wheel above the end eye.
S36 C1 compression damping adjuster
C1
Adjustable compression damping. Adjuster wheel or slot on the reservoir.
L
L
Adjustable length.
Technical data
Piston diameter: 46 mm
Length: 277 mm
Stroke: 46 mm
Rate N/mm: 170 N/mm
Position: rear
Mounted spring: 01104-69
Packaging unit: pieces
For you folks running an ohlins,JRI or K Tech ( not heard of anyone else with K Tech except me?), how hard is it to adjust your preload?the ohlins looks like it uses a notched collar, so a regular spanner with a "hook" at the tip. My K tech has holes for a pin type spanner, and it appears JRI shocks are the same? Either way, the collars are so far up in the bike it's making adjustment **** near impossible. Also, anyone have a cheap source for a pin type spanner? I picked one up at the shop but it may be too big. As in, the pin is a bit too big for the holes.
1 - 8 of 8 Posts
