1 - 3 of 3 Posts
Hey,
Just bought some Oxford Hot Hands Heated Over Grips.
They drain 3A from the battery, does anyone know if this is going to cause issues, e.g. excessive drain?
Thanks in advance
Adrian
They'll be fine as long as you tap into an accessory line ( the lights or ignition for example so it turns off when the bike turns off). If you don't do this and accidentally leave them on, you will almost certainly come back to a dead battery.
They have a low battery mode, so you shouldn't have to worry about battery drain if you leave them on. They turn off once they detect a reduced charged from the battery.
1 - 3 of 3 Posts
