So I installed a PCV which supposedly came with a requested MAP for full exhaust, high flow filter, smog pump removed and 5000ft elevation, the bike ran like crap with a big hesitation when applying throttle , scary when exiting a turn, it did seem to have a bit more snap to it otherwise, so being computer stupid I spent alot of time figuring out the download procedure from PC, as far as I can tell there are only 3 MAPS available for download, stock, slip-on, and full yosh system, after going over the charts I find the stock to be the richest in the range the hesitation occurs ( if I'm reading things correctly) so I loaded it, the bike runs better, the hesitation is barely noticable. the MAP which came with the PC was for the full Yosh system not including the other mods.
So what gives with a full system needing a leaner mix?( according to the PC maps) this is opposite of what I would expect to see.
I have searched and could not find other MAPS for specific set-ups available elsewhere.
Any advice to a newbe with PC would be appreciated, or pointing me to an appropriate MAP I can dowload, Dont want to hurt this bike running lean.
