1 - 9 of 9 Posts
So I have an R3 2016
Is it Bad that I never use neutral, as in I hold the clutch in when I wait at stops and what not?
Nope that's what you're supposed to do that way if someone isn't paying attention behind you to stop, you may have a chance to get out of the way. Also it's easier to get the bike to 1st coming to a stop than from neutral to 1st while not moving.
So I'm not damaging the clutch or the lever at all?
Nope, when the lever is fully pulled in the clutch is 100% disengaged, it's basically the same thing as neutral because no power is being delivered to the wheel. The lever won't be harmed, this is exactly how it's meant to be ridden :). The good thing about bike clutches is they're MADE to be slipped unlike a car, so they'll last a very long time even when slipping (not that I'm suggesting you are sitting at a light, you're not).
Fosho, thanks man, that really explains A lot
It's not safer... Good luck getting your bike into 1st when an idiot behind you won't stop... You SHOULD be holding in the clutch at a light (I wouldn't if I'm in bumper to bumper not really moving, but otherwise I have the lever in). Really it's all personal preference, but I'd rather be able to get the **** out of the way of a car than not be able to hold the clutch lever down for a minute.
You DO make a good point :eek:
No, you're not damaging anything.
It can take a lot of abuse, holding it at a stop light isn't going to do anything.
1 - 9 of 9 Posts
