1 - 3 of 3 Posts
Hi guys
after 2000 miles i upgraded my front caliper to brembo P4 40mm ones
they came with brembo brake pads
since its a different brake pad will the bed in process reset ? or is it quicker than normal
my first time switching to brembo from oem
many thanks for any infos
Just bed them gradually raising them up to operating temps under 40 mph with 1/4 mile between brakes about 10 times then take it to 60 and slow down hard about 10 times with 1/4 mile between brakes is what I do.
Which pads are you using? Some are designed for 'racing' applications and work best when hot. If you are not doing a lot of hard braking, you won't build up enough heat for them to work at their best.
1 - 3 of 3 Posts
