1 - 10 of 10 Posts
So I'll "try" to keep it short and say I financed a new 2015 Yamaha R3 a while back. Real fun bike! Very comfortable and sporty lightweight motorcycle. Seeing how I financed it I don't want to get rid of it. Recently however I started getting a little bored with the power. I got around to thinking of a similar and compatible engine to perform a fairly easy swap and came across a 2015 Yamaha FZ-07 engine out of a wrecked motorcycle.
I googled and googled and did all the research I could think of doing. They appear almost identical. Yamaha Parallel Twin Cylinders. Both are 2015. Weight is very close. The mounts are almost identical. I'm wanting to take a shot at swapping engines. The FZ-07 almost looks like a direct replacement! It looks like everything is identical and I can just replace my R3 ecu with an FZ-07 ecu and that's all?
The wiring harness on my R3 appears identical. Looks like I can just unplug my R3 ecu and plug in the FZ-07 ecu?
The FZ-07 engine I have is complete with throttle bodies and airbox. Which also look identical but I'll swap all this out because it's already attached to the FZ-07 engine because it was pulled from the wrecked motorcycle fully intact.
The exhaust is virtually identical as well. I see no reason why I couldn't perform the swap but just thought I'd check on here before I start pulling the engine. Any info that would be helpful and informative is greatly appreciated. Any links related please post. Thanks!
Hope it all works out man keep us updated! Can't wait to see the result, would love to do the same
Although the idea of having a punchy engine of the fz 07 in a small R3 frame would be neat, I'd rather save the effort and buy a 07, assemble a fairing kit--oh wait they need to make the fz 07r happen now!! I'm drooling over the idea..
Man this has been beat to death on many a' forum. Someone does (or did) make an $$$ aftermarket race fairing for the FZ-07.
1 - 10 of 10 Posts
