You can eliminate the stock brake switch with a banjo bolt operated one.
Goodridge, solid good quality.
http://www.ebay.com/itm/Goodridge-B...ash=item4d423c7960:g:OrkAAOSwxp9W3NpW&vxp=mtr
This one from Hong Kong would work if you are on a tight budget.
http://www.ebay.com/itm/Universal-M...ash=item1e9d52c12c:g:JJ8AAOSwo6lWPEre&vxp=mtr
Brake pedal height on most rearsets account for race boots or aggressive angle. You can cut or replace the shift rod on the left side as needed. There are vendors that can help you with various lengths.
Graves makes a return spring if you find you need it. Should be just ok without it with brakes setup ok in the back. Report back.
