From your description, sounds like your rear brake may be dragging.
Go ride it a bit and try not to use the rear brake. Stop and feel the rear brake rotor (carefully) - is it hot, or even warm to the touch? If so, brake drag.
Possible causes:
A) Check rear wheel alignment, which may have changed during servicing (tightened one axle adjuster more than the other) - correct if off.
B) Caliper may be sticking - remedy with liberal use of brake cleaner.
C) Operator error - is your foot resting on the brake pedal when you ride?
Possible causes:
