1 - 3 of 3 Posts
Does the oil pump / clutch recall require draining the oil? Pretty sure it does. Just curious why the dealer didn't bother to change my oil. Did they just drain, then refill with same old oil? Seems kind of cheap. Also on the parts, it just lists oil pump assembly. How would I know if they also changed the clutch bearings?
Does the oil pump / clutch recall require draining the oil? NO, SEE DEALER SERVICE BULLETIN. Pretty sure it does. IT DOESN'T. Just curious why the dealer didn't bother to change my oil. BECAUSE ITS NOT NECESSARY AND THEY WONT GET PAID FOR IT. Did they just drain, then refill with same old oil? NO, POSSIBLY A LITTLE. SEE DEALER SERVICE BULLETIN. Seems kind of cheap. Also on the parts, it just lists oil pump assembly. EVERYONE'S PAPERWORK IS THE SAME. How would I know if they also changed the clutch bearings?
1 - 3 of 3 Posts
