how did you end up installing it as i would like the same mount.Can (and how to) I remove the silver bolt to install a quad lock stem mount? View attachment 68678
Thanks for the tips, appreciate it. Just wish it was closer so it would arrive sooner. The case arrives today.Remove it with the appropriate socket (I forgot the size) and replace it the same way. the stem nut holds the top triple on but does not preload any bearings. Do be careful about overtightening as the replacement bolts are normally made of aluminum and have a higher possibility of stripping.
Do you have a link for the bolt you bought by chance? I wonder if you you can remove the ball and use the fork stem mount.It's a 21mm if memory serves me correct. You will need a wrench with some length to it to get it off. The new stem bolt from MNNTHBX uses an Allen head to install, which I think is an 8mm (it's been a little while). I would use a 3/8" socket and not an Allen wrench for install. I used a very small amount of blue Loctite on mine, just for a bit of insurance, but I don't think you need it.
I really like mine. I wasn't sure about the whole setup considering the price of just the MNNTHBX stem nut to begin with, but the whole setup is super clean, stable and minimalist on the bars. Now if I just had some touch screen-friendly gloves to actually be able to adjust map apps without having to pull over and take my gloves off.
Also, if you are looking for QuadLock parts and mounts, I have a partner discount code for 10% off.
Thanks, i ordered this one as well to see if i can use the fork stem mount, i was just hoping for something to arrive sooner but i like the look of your setup.There is no ball removal. It's a one-piece machined stem nut with the ball mount on the end. Looks like it is currently on backorder, but I would say, it's worth the wait.
Nope, they are the same size on all years. The main difference in the front suspension is the triple clamps and forks.![]()
17.93US $ 31% OFF|Logo Yzfr3 For Yamaha Yzf Yzf R3 2015 2016 Motorcycle Accessories Cnc Engine Triple Clamp Oil Filler Cap Plug Bolt Screw - Covers & Ornamental Mouldings - AliExpress
Smarter Shopping, Better Living! Aliexpress.comwww.aliexpress.com
My nut is 22 mm on my 2021, it might be a different size on other years though.
You can always drill and tap the stock steel bolt to accept a screw. That eliminates the use of an aluminum bolt in the application.Does this bolt worked for you with the stem mount? I am having the same issue
