Saddlemen Track CF
I picked up both the low and standard versions of the Track CF model. Track CF model is all Carbon Fiber pattern vinyl, the GP-V1 version has sticky pads to grip your inner thighs, pillion cover is included in purchase. Very hefty design, solid without a doubt. Vinyl is riveted rather than stapled to the bottom. You will have to transfer the rear mounting plate from your original seat to the Saddlemen with the supplied bolts.
Adds much more comfort and cushion over stock. Would be a huge difference to long distance riders/commuters. Those of you looking to add height, this is it.
Even the low version has more padding than the stock seat. It adds just a touch more total height to the bike, as I could tell pushing the bike in reverse. I couldn't tell a difference cushion wise between the two, only in overall height.
Pic 1 mounting plate already transferred to the the new seat. Notice rivets.
Pic 2 Standard thickness seat. Notice the pronounced channel.
Pic 3 Lower version. Less channel depth.
Pic 4 Seat completely installed and included pillion cover placed. The pillion cover is not completely installed yet. I just stretched it out for this picture. They recommended I return with passenger portion and they will remove original cover and staple the CF cover on in 15 to 20 minutes. I will probably do that on Monday.
