At very low speeds. By low, I mean 1mph. 2mph at most.
If you are curious, Yamaha OEM frame sliders will do absolutely nothing at those speeds. They will essentially be nothing more than decoration. None of the side fairings contact the ground. None at all, all the side fairings are in perfect condition. I mean every single plastic body panel has no damage or contact to the ground after 2 drops.
As far as damage goes, it is minimal. The brunt of the damage was on the footpeg as it was bent. Then some scratches on the exhaust. Minor scratches. Some very small scratches on the mirror tip and very minor scratches on the handlebar end. The front turn signal is scraped at the bottom, so you cannot see it but the thing just pops out completely both times when it hits the ground. I just popped it back in, and later in the garage, opened up the inside panel to put the plastic retainer clip back on the rubber sleeve.
Aside from the bent footpeg, you look at it, you wont think it has been dropped twice unless I point out all the small scratches on it.
So yeah, those OEM frame sliders will probably only do its job for drops at speed. Not standstill/low speed drops.
And if you are wondering how she drops it, she has a NASTY BAD HABIT of using front brakes on low speed maneuvers. Add that with a turned front wheel and you get the picture. Past 2 days I've been having her practice not touching the front brakes when going slow. Gotta keep this up until she gets it in her head.
