1 - 3 of 3 Posts
Hey guys i recently had a blown fuse which caused the light/inndicators to stop working, after replacing all the fuses and getting that to work again ive realised the speedo and odo do not work when i ride. Anyone know the problem for this? ive had a look at the manual and cant seem to find anything
Why did you have to replace the fuse? Did you short something by accident?
Could be the speed sensor has gone bad due to whatever shorted and popped your fuse.
With the key on, put a multimeter set for DC 20V and check to see if you get a fluctuating reading from the speed sensor while spinning the rear wheel by hand. It should cycle between .6 and 4.8V. Theres 3 leads one is ground, one is power and the other is the wire you want to see the fluctuating reading on.
i shorted my fuse when reconnecting the lights after installing my tail tidy, ill have a look with the multimeter.
1 - 3 of 3 Posts
