1 - 2 of 2 Posts
Man I have only ridden a few times but really had to reach for the clutch and for the brake I found it uncomfortable to have my hand nearer the bar end for throttle using the stock brake lever. So shorter brake and closer clutch.
The brake lever is awesome. Got it dialled in and it’s in the perfect spot. Clutch I guess is closer but it still feels too far away. Bonus I guess it feels firmer in the clutch side like less play and I need more force to disengage the clutch. Yes I did adjust free play.
install of the levers was straightforward but I changed the color of the switches that adjust the position and that was a fine motor control beast that took me thirty minutes. Suggest you use a chopstick or something with a broad flat end to compress the ball bearing and spring unless you want to shoot your eye out.
68128
1 - 2 of 2 Posts
