Depends on what country the bike is from, here in the uk my stock indicators at least didn't use the washer and locknut under the rubber bushing the bushing just had a screw through it into the indicator, Also another odd fact the uk turn signals use the bullet style crimp connectors instead of that yamaha style turn signal connectorCan you remove the rubber bushing and re-install tight with a washer and locknut? Not sure how the Yosh eliminator assembles, but with the Vagabond eliminator the stock rubber bushing is removed before attaching with washer and locknut. The signals are tight and don't rattle around or loosen.
That seems to hold it a bit better but I was wondering if I could buy any other aftermarket indicators that fit on the yoshi fender kit.Can you remove the rubber bushing and re-install tight with a washer and locknut? Not sure how the Yosh eliminator assembles, but with the Vagabond eliminator the stock rubber bushing is removed before attaching with washer and locknut. The signals are tight and don't rattle around or loosen.
Retainer clips? The ones I had to snip off to even install this? I'll post some pics of this morning.Man, I love Yoshimura but their fender eliminator sucks as. I don't understand why they would make it like 5 pieces. Its a disaster.
Anyway, what is falling off, falling from the signal retainer clip, or the nuts vibrate off? Or wait, better question, did you reinstall the signal's plastic retainer clips inside the rubber?
Bon apetit!
