Hey guys,
I'm quite heavy guy (220 lbs)(100kg) (6"3)(192CM) and I'm looking for a cheap way to stiffen the front forks suspensions a bit. I'm not racing the bike however I ride a bit on agressive side on twisties around here. I was wondering what is the best way to choose to adjust the front forks to my weight. I'm considering adding a little bit more oil into the forks/ changing the oil for higher viscosity/ or putting preload adjusters (or basically putting some spacers inside the stock ones). I'm student therefore quite bit short on cash looking for cheap and good solution. I'll appreciate any tips!
P.S.: I wanted to consult these tweaks before considering buying new springs which is a bigger investment.
Cheers,
David
Cheers,
David
