I have a 60th anniversary R3 always ran fine no issues but I dont ride it that much but I do start it at least once a month.. and keep it on a battery tender.. One day, I went to start it and it wouldnt start.. so I replaced the battery.. the original battery was still in it. so new battery and started it started up fine.. ran for about 5 minuets idleing and died and no start afterwards.. I figured the new battery might not of been fully charged so I charged it up and again nothing. So I figured maybe a bad battery so took the old one back and got another one.. same issue no start.. checked the voltage on the battery and it was fine...now I can hear the fuel pump priming up... but no start.. so I changed the plugs and still no start checked all the fuses all looked good.. so... to see if I had a fuel problem.. I took a old rag soaked with rubbing alchohol and held it up to the intake.. started right up several times.. runs and as soon as I take the rag away stalls out.. so its not getting fuel.. what should I check next? or replace.. fuel relay switch>? what else any help appreciated Thanks
