Check out this picture of the R25's speedo at 12,500 RPM. 173 kmh or 107.5 mph. So figure with the increase of 50cc's R3 will get 115 mph is MORE than possible
Were all runs made in the same direction?I thought something was wrong as well, but I did this multiple times. Not very windy where I'm at either. I always thought the cooler air would give the engine more power, but I guess on the lower powered engine it doesn't make enough difference. My guess is that in the cooler air in the morning it is also denser creating more wind resistance, while in the afternoon when it's warmer the bike seem to slice through the air easier.
It is a very long flat stretch, one of the days I did do a couple passes back and forth and nothing changed. If it's not the dense air creating more drag I guess only things left would be tire pressure expanding from the heat and increasing the circumference of the tire. Or maybe it's something to do with the fuel map.
If heat increased the circumference of the tire that would only make him go faster on GPS, his motorcycle speedometer would be the same. He didn't say whether his readings were GPS or motorcycle derived.It is a very long flat stretch, one of the days I did do a couple passes back and forth and nothing changed. If it's not the dense air creating more drag I guess only things left would be tire pressure expanding from the heat and increasing the circumference of the tire. Or maybe it's something to do with the fuel map.
With a small engine, the weight of the rider, terrain, quality of the tuck and wind direction can cause a 5-10 mph difference. However, 194 (120 mph) seems to be the top speed for the average weight rider, 175 lbs.R3 with 3,000miles
Stock morning topped 106mph
Same day afternoon 117mph
With fender eliminator and slip on
Morning 111mph
Afternoon just tipped 120mph
I believe the R3s rev limiter is lower than the R25s because the R3s larger pistons weigh more. That equates to more stress on them, and on the connecting rods, at any given piston speed and could cause the connecting rods to fail at the R25s higher top RPMs.With a small engine, the weight of the rider, terrain, quality of the tuck and wind direction can cause a 5-10 mph difference. However, 194 (120 mph) seems to be the top speed for the average weight rider, 175 lbs.
For some reason, the rev limiter is lower on the R3 than the R25, because it revs to 13000 RPM before the limiter shuts it down. Also the power drops off significantly after 11,000 rpm, so continuing to rev it through the gears gets you nothing.
